opened front panel and no flame. Igniter not glowing.Checked coils ok.I am guessing maybe I need a igniter?
There are five major electrical parts involved in the heating process:
- High limit thermostat (#17 on the gas valve break down diagram)
- Cycling thermostat (#8 on the motor break down diagram)
- Igniter (#4 on the gas valve break down diagram)
- Flame sensor (#18 on the gas valve break down diagram)
- Gas valve coils (#7 on the gas valve break down diagram)
How to find out which part causing the problem?
Pretty simple: all of these parts have to be tested for continuity in the above sequence.
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
If any of them is open – it has to be replaced.
Gas valve coils also could be tested by resistance. There are two coils – one with three terminals and one with two terminals.
- Coil with two terminals should have 1220 ± 50 Ohms
- Coil with three terminals if held with terminals in upper position:
a) across the left and the middle terminals – 1365 ± 25 Ohms
b) across the left and the right terminals – 560 ± 25 Ohms
The part number for the high limit thermostat is [COLOR=#0066cc]AP275754[/COLOR]
The part number for the cycling thermostat is [COLOR=#0066cc]AP276896[/COLOR]
The part number for the igniter is [COLOR=#0066cc]AP3109449[/COLOR]
The part number for the flame sensor is [COLOR=#0066cc]AP2910747[/COLOR]
The part number for the gas valve coils kit is [COLOR=#0066cc]AP3094251[/COLOR]
Here are the break down diagrams for the Maytag dryer Model MDG7057BWQ
Thanks Gene. I guess I really did not need to ask this question as you have answered it so many times in this forum.My igniter was cracked.This forum was a great help made changing this part a very simple process. Thanks again.
