Maytag Dryer knob
I am confused, I was just about to order the dryer timer assembly and the new knob parts, and I noticed the question string on the order page. Apparently, the manufacturer used a couple of different timer assemblies for my model number dryer. The technician asked for the serial number to make sure that the timer was the correct one for my machine.
The serial number is: 10151848CJ Can you please confirm which timer model I need for this dryer and the difficulty of replacing it myself? Thanks so much!
LA
Hello. These are not to hard to replace. Just disconnect the power and remove the back panel on the control panel. Then remove the center of the timer knob and pull the old knob off the timer. Remove the old timer and unplug the wires going to it. Reinstall in reverse order with the new timer. Below is the correct timer based on the model and serial you provided. Hope this helps.
AP6007999
