The parts website shows different elements to use. One is a repair kit. My old element has stamped on it 5.35KW. Which one do I use? They are different prices so I figure one is heavier duty maybe. Thanks
I only see two elements for this dryer. They are listing them multiple times in the parts description which is confusing.
The cheaper one comes without the thermal fuse and over temp thermostat, the more expensive one has the extra parts. I prefer the more expensive one. I find that changing both of those parts and the element at the same time is a good idea in the long run.
Also there is a part number change after series 14. So you would need to check your model number for that.
