Maytag Dishwasher
“Light” cycle on dishwasher does not work.
Replacement parts for MAYTAG MDB7709AWW2 UNDERCOUNTER DISHWASHER | AppliancePartsPros.com
Check under the unit for the tech sheet.m Often it is tapes to the back of the kick plate.
If upou cannot find it let me know and I will try to get a copy for you.
The problem could be the control panel (keypad) or the control board.
In the tech sheet you will see a ribbon cable pin output list.
each ribbon cable track is common to several keys so see it the keys that use the same tracks as the “Light” cycle are working.
The usual way to trouble shoot this is to check the keys (Ribbon cable) with a meter. If the keypad checks out OK then replace the control board.
Still a bit of a crap shoot but your odds are better.
If you see that the keys on a certain track do not work you may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
