I have a 2year old maytag dishwasher. I started having problems with the buttons only a couple worked. Then it died No ligts nothing. The non resetable bi-metal an the door switch checked out o.k. I have power to the control board So I changed the control board. NO LUCK! Still no lights Cannot run a diagnostics check. No Lights. HELP!! PLEASE! THANKS!
Karlie,
Based on your post information, You’re going to need to replace the control panel / keypad assembly,
The control can’t see the selection made, because the circuits aren’t registerring correctly.
Thanks,
