Maytag dishwasher WU1000
I have a Maytag undercounter dishwasher WU1000. When I selected Energy Save Cycle it started to work, then after about 3 minutes the touchpad leds and the number 88 started flashing continuously until I turned off the breaker.
I was able to get it to run in Normal Cycle but it went into the same flashing pattern after finishing a proper wash and rinse cycly (72 minutes).
Do I need to replace the touchpad electronics or something else?
thanks for any input. It works perfectly in all other regards, so I don’t want to replace it.
Sounds like the problem is a bad control board. Unfortunately this part has been discontinued by the manufacturer and is no longer available (like many other parts for this model). Looks like it’s a time for a new dishwasher.
Here are the breakdown diagrams and Replacement parts for MAYTAG WU1000 Dishwasher - Undercounter | AppliancePartsPros.com
I took someone’s advice from this forum and cleaned the ribbon connectors going to my control unit. The dishwasher worked perfectly in Saver Mode until it got to the very end - it failed to pump out the water.
When I pressed the “dr” drain button, I can hear the relay click but nothing happens. I turned off the breaker overnight and it drained properly.
Could it be something besides the control unit? I really don’t want to spend $180 on a 1988 dishwasher when I can get a new one for $200 after the new rebate.
Thanks in advance for any suggestions.
[quote=ptcicca;202443]…The dishwasher worked perfectly in Saver Mode until it got to the very end - it failed to pump out the water.
When I pressed the “dr” drain button, I can hear the relay click but nothing happens…[/quote]
Remove the toe panel at this time and check how hot is the motor on touch. Check how freely the pump and motor pulleys are moving in both directions.
[quote=Gene;202508]Remove the toe panel at this time and check how hot is the motor on touch. Check how freely the pump and motor pulleys are moving in both directions.
Gene.[/quote]
Gene - Thanks for the tip. I’ll try that. More info - the dishwasher will run OK as I said, pumping out the water after the wash cycle, but not after the rinse cycle. Once it finishes running, the drain “dr” function does nothing. BUT, if I let it sit for a few hours the drain function then works fine when activated manually from the touchpad.
If it is not a belt problem causing overheating, could it be an electronic component that is simply malfunctioning above a certain temperature caused by the hot water and/or the dryer element?
IF that is the case, will an ohm meter tell me anything?
