I have replaced control panel because the latch had broken!! The machine ran for 2 to 3 loads then quit!!! I replaced with another new conttrol panel and the same thing happened 2 to 3 loads then wont start!!! I can change cycles and the panel lights up, but go out after 30 sec or so. I have checked the switches for cont, and are ok. Is there some type of reset that should be used??? Thanks Ron
Hi.
Let’s try the following:
With the dishwasher in “Quit!!!” position unplug it for a few minutes, then plug it back in.
If it will work for a couple of loads and the stops again, then most likely you need to replace the control board.
The control board [PART]99003160[/PART]
Her are the breakdown diagrams and Replacement parts for Maytag MDB6600AWW DISHWASHER- UNDERCOUNTER | AppliancePartsPros.com
Thank you. Post the results.
Simon.
I have cut the power for a few hours and repowered, with same results!!!
Hi.
Replace the control board.
You can always return unused parts even if they been installed.
Simon.
