This 13 month old diswasher will not respond to the start button. When I push the heated dry and normal wash buttons twice in succession, the wash and clean buttons light up, and a 5-10 minute cycle will run. Do I need a new control panel?
Replacement parts for MDB7609 models | AppliancePartsPros.com
Here is a link to the tech sheet
Data File Host
Although your model number was short several digits I think the above is the correct tech sheet.
The problem may be the control panel (keypad) or the control board.
The normal way to troubleshoot is to check the keypad with a meter is it checks out OK then order a control board.
Still a bit of a crap shoot but your odds are better.
If a number of keys do not work and use a common line then try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
Read more: http://forum.appliancepartspros.com/dishwasher-repair/238531-dishwasher-repair.html#ixzz1OOp52c57
