Maytag dishwasher won't drain
Good morning,
The problem I’m having is that the dishwasher runs normally but when it finishes it’s cycle it goes off but it does not drain. No sound or anything just simply ends. No flashing lights or anything like that. When I press the cancel/drain button it will start draining, so I know that there is no blockage.
I’m guessing it could be the control board; some circuit. NOTE: the control panel has already been replaced and is less than a year old so that shouldn’t be the problem.
Any advice would be helpful.
Sounds like your main board if it works every single time you press it cancel drain and it works properly and you have no objects in the drain pump or drain line then replace it.
Here’s your parts
02-Control Panel Parts parts for Maytag MDB7609AWW2 - AppliancePartsPros.com
This is an EZ fix if we had similar encounters. My dishwasher would start and then it would not complete the cycle. It would stop, and at the end of the cycle, there was water in the bottom, and also a little leaking.
The machine stopped mid-cycle because there was impaired draining from the the hose, so I replaced the drain hose, and everything started up again. My family was going to replace the machine, but it was a $8 fix. I made a video of the repair, so this video is helpful if your machine stops during the cycle, doesn’t drain the water, or is leaking, or if you just want to replace the drain hose before it becomes clogged.
My Kenmore Dishwasher Won't Drain and is Leaking- How to fix or repair Clog or Leak. Not pumping. - YouTube
