My Maytag dishwasher model WU300 will not drain. The rest of the cycle works and the motor runs. If it were a plugged hose or filter wouldn’t the motor/pump still run for at least a short time but just not drain the water? When the timer runs to where the drain cycle is the motor does not turn on and drain the diswasher. Is it more likely the timer or something like a drain solenoid and how can I tell?
Thanks.
Hi.
Most likely it is the timer, but here are the bad news: most of the parts for this model are no longer available.Including the timer.
Sorry.
Simon.
