Dishwasher is stuck on drain cycle. Maytag real new. Cannot clear or get it to do anything else. You can put water in it and it will drain it but will not advance.
Hi ak47jazzfan
How exactly old is your dishwasher? I need you to post the complete model number.
Maytag it is about a year old and the model # is MDBH955AWB
Hi ak47jazzfan
Most likely the problem with your dishwasher is a bad control board. If your dishwasher is less then a year old it’s still under the manufacturer warranty.
If it’s more then a year old and you would like to fix it yourself, the part number for the new control board AP3856447
Good luck.
