After the dishwasher cycle is completed and the door is open, water keeps coming in the tub at a very slow rate. Eventually it will fill the tub and overflow.
Hello Richard. There is a couple of things to check for here the first being AP4113388 the way we check to see if the valve is bad , is to turn the power off to the unit while its filling with water,if water keeps coming in , replace the water valve. Second thing to check is the float switchAP4366557 sometimes they stick open. It is good to run some AP5691606 thru the unit, this will help all the inner parts with soap build up. Thank you and good luck !
