my normal wash button and my start cancel botton won’t work .. so i can’t start my load.is the problem in my control panel or the control board?
A model number may help others help you.
It could be either the control board of the control panel, a model number may let someone look up the wiring diagram so that you can check the control panel which should better your odds of getting the correct part.
You could try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector.
