Maytag Dishwasher has door leak
Replaced door seal, soap dispenser seal, rinse aid dispenser seal and still leaks from lower middle of door, but not as much as previously. If you take out the lower spray arm, the leaking stops when running the dishwasher. There is no noticeable damage to the lower spray arm. The test run was without dishes. Perhaps that makes a difference. Any advice on where to look next would be appreciated.
Maybe a split on the end of wash arm??
