Brand:Maytag
Model Number:MDB4949SKZ3
Main Symptom:Grinding Noise
What happens & when: pump running
Error Code (if any):NONE
Brand:Maytag
It would be recommended to check the pump to make sure that there is nothing that has gotten into the pump and causing the noise. If there is nothing int there then this would likely be a bearing that would be faulty and need to replace the circulation pump.
