Maytag Dishwasher control panel doesn't light up
I have a Maytag model MDB9600AWQ and it is still working, however, about 6 months ago the front display that shows time remaining and the top control panel that you select the cycle and options went out. It was tempermental at first, it would work sometimes then it would stop. Finally it just went out completely. The start/cancel button still works, so I can at least use the machine. I always used normal cycle, so I’m guessing it works only in that mode. Any suggestions?:frowning:
The touch panel will need to be replaced and is available at the link below. It is accessed for replacement by removing the screws from around the inner door and separating the panels. It simply unplugs and plugs in to the main control, making replacement pretty easy.
Whirlpool 6-917721 Panel-Con - AppliancePartsPros.com
Before replacing the panel you may want to try the following.
Connector Cleaning / Checking
Unplug the unit
Open it up
Clean the edge connector. Use electronics contact cleaner or isopropyl alcohol.
