Dish washer get to the 43 minute mark on the timer and then seems to quit working and Ideas?
Hello I would go to the AP5272754 drain pump and check for clogs,also check at the drain hose, where it hooks up under the sink,for clogs, then I would run AP5691606 cleaner thru it this will help keep this from happening, Thank you and good luck !
