Maytag Dish Washer Won't Drain
Maytag PDB3600AWE assembled 09/2002 doesn’t drain. It seems to be otherwise functional. Please advise on troubleshooting in order to determine what part I need to order. Any assistance is greatly appreciated.
1st thing if u have had a disposal installed or replaced make sure they knocked the plug out if that is where ur drain hose goes to. then check hose for blockage if none of these the probably pump/motor asm
