Maytag D/W Not Starting
My Maytag D/W Model# MDB6601AWB does’nt start, only 4 of the 12 switches light up (Heavy wash, Rinse only, Instant wash, and Autoclean). The lights will stay on for 30 seconds and will switch off, and nothing else happens. I replaced the CNTRL-ElEC circuit board WPL W10218837: No change. :confused: What’s wrong, do i have to change the PANEL-CON 6-919822, please advise
Replacement parts for MDB6601AWB models | AppliancePartsPros.com
Here is a tech sheet, see the attachment.
It does look like a number of the keys you mention do use the same common wire/ribbon cable track.
I would check the output of the keypad/console with meter.
With luck you may be able to confirm that is is the problem.
Unplug the unit
Open it up
Clean the edge connector.
Check the key outputs with a meter.
MDB6601.pdf (676.6 KB)
