trying to figure out which part I need to convert this Maytag Portable Dishwasher to a built-in one. I cannot find this specific model anywhere. The model is MDC4809AWW4
Thanks for your help!
I couldn’t find a kit either. Usually they had a set of leveling legs and maybe two rollers. A drain hose. A different water valve or an adapter for the original valve. And two metal strap like things that hold the DW in place under the counter, oh and two screws.
I’ll see if I can find a pic. instead I found some links.
Parts for Maytag MDC4809AWW4 / Dishwasher - AppliancePartsPros.com
I don’t know if this is the right kit, but it might give you an idea.
