Maytag Commercial Dryer
Customer Has This Dryer That Randomly Decided To Display $1.50 Per Cycle In The Led Display As Opposed To The $1.75 That It Used Display, She Also Said The Time Reduced. There Is No Coin Shute Like The Old Days, Just A Coin Slot And It Is Electronic In Nature. I Am Thinking It Can Be Adjusted Manually By Manipulating The Control Buttons (there Is Only 3 On This Model) Once In A Mode That Would Accept That, However, There Is No Tech Sheet I Can Find On This Dryer Nor Was There One In The Machine To Guide Me Into The Process, Anyone Know??
Hey Jeff
Did you find an answer to your problem?I have the same situation.
