How can I unscrew the bolt to remove the clutch. one said to take a large screwdriver and jam the belt, but I don’t understand how. There must be a simpler why to do this. If anyone can help it would be greatly appreciated.
i have never really had an issue with this, but i usually use a crescent wrench and grip the as it goes to the motor and after the motor. i then try to make the 2 sections of belt touch. that keeps the clutch from being able to move. i have never used anything but a short 1/4 socket wrench to remove. perhaps tapping the wrench with a hammer will coax it out. this is standard thread, not to be confuse with the basket drive shaft which is counter thread.
[COLOR=#333333]it took me forever to get the bolt out using just my hands holding the clutch as I unscrewed the bolt. But now that I replace it with the new clutch, I’m having a hard time screwing in the bolt using a torque wrench as instructed. (96 in lbs.). I can’t picture what you explained using crescent wrench. I wished there was a photo of this. But I do thank you for helping me. [/COLOR]
[FONT=Calibri][SIZE=3][COLOR=#000000] [/COLOR][/SIZE][/FONT]
