Maytag Centennial Washer is Loud
I have a Maytag Centennial MVWC200XW2 top load washing machine that’s loud only during the spin cycle.
The washer works okay but it’s loud during any spin cycle.
You are probably hearing a bearing noise during the spin cycle. Here is a link to the part you will need. keep in touch and let me know how the repair wemt. W11454741 Washer Gear Case | Genuine Whirlpool OEM In Stock
My advice would be to use it as it is and if you can’t stand the noise anymore.Buy a new washer as it looks like it has some age on it.And there would be more to it after you change the gear case like Calibration must be performed
when any of the following components have
been replaced: Main Control, Basket, Drive
Assembly, Suspension, Motor, and Capacitor.
