Maytag Centennial not drying
My gas centennial has stopped drying things? It seems to not be getting hot. I had it on Automatic dry (high heat) under energy preferred setting, came to switch about 2 hours later and was still on same setting and clothes were cold and damp?:confused:
Hello.
You would need a multimeter to run the tests. if you have one - buckle up!
Remove the rear cover from the dryer and locate thermal fuse
AP6008325
Pull one wire off and check continuity. If it’s open (no continuity) - replace the fuse and make sure that entire exhaust system is clean.
Next check the thermal cut-off and limit thermostat
AP6047982
Replace if open.
Here are the breakdown diagrams and 03-Bulkhead Parts parts for Maytag MGDC400VW0 - AppliancePartsPros.com
Please let us know the results of the tests.
Simon.
