The washer works in Spin cycle. However at start up no water is comming in.
I checked the hoses and the screens everything is very clean. This new machine has an auto fill . Is that my problem?
Remove the washer cabinet.
[youtube]OlAFQnkapLM&rel=1[/youtube]
Check for 120 VAC to the water inlet valve solenoids while the washer in the fill mode and the water temperature switch is in different positions. Post the results.
Here are the breakdown diagrams and Replacement parts for MAYTAG MVWC6ESWW0 AUTOMATIC WASHER | AppliancePartsPros.com
How to remove the washer cabinet.pdf (43.7 KB)
Gene ,I checked with a volt meter no power to cold or hot . No change in power when I change temperature control.
Check for continuity the thermistor (at the end of the water inlet valve). If it is open or shorted, replace the water inlet valve.
- The water inlet valve AP6016325
[LEFT][quote=Gene;341677]Check for continuity the thermistor (at the end of the water inlet valve). If it is open or shorted, replace the water inlet valve.
Gene
What is a thermistor ? like a resistor, I found two single wires under the hot and cold valves. I removed the two single wires use volt meter and it checks open is that the thermistor? Can the thermistor be replaced by its self? Or the whole valve?
[/LEFT]
According to Wikipedia “a thermistor is a type of resistor whose resistance varies significantly (more than in standard resistors) with temperature”.
The thermistor is located at the end of the water valve nozzle. It can be recognized by the two wire terminals.
If your voltmeter was set to measure resistance and it shown that the thermistor is open, replace the water valve. The thermistor comes as a part of the water valve only.
The volt meter says its open so I will order the part and replace it.
Thanks Gene:)
To Gene, I replaced the inlet valve with the thermistor. I here the machine now agitating but no water is comming into the machine. This machine has a auto fill level do I need clothes in the machine.
Remove the washer cabinet and trace the pressure hose (#21 on the diagram) from the outer tub to wherever it is connected inside the control panel. Post the result.
Visually inspect the electronic control attached to the back of the timer for any cold solder joint or burned spots.
I also attached the electric schematic for the washer.
MVWC6ESWW0.pdf (301.9 KB)
The following is the information provided by the other expert Jeff Kelley:
“The water valve is energized by this switch AP4501024 . This is a switch which contains a small control board inside. The load sensing switch. If it is bad the water will not come in and the valve will test bad. I have repaired hundreds of these machines with this same problem. This is what I use to fix them. Hope this helps!”
I checked the hoses removed and ran water through them no clogs . So I put all the hoses back on. Then I removed the both of the clips to water solenoids
One at a time I put volt meter in the clips that go to the water valves. I have no voltage on any cycle to the solenoids . The wiring diagram shows a fuse . Is the main control knob fused? If so where? I would have to take the main control apart to see anything Burnt. Also I see a blue capacitor could that burn up? Any ideas ?
There are no fuses in this washer. If you mean the part shown on the top left part of the wiring diagram then this is the lid switch as described in the legend on the left side. There is nothing wrong with the lid switch because the washer does spin.
The reason why I asked you to trace the pressure hose is to find where it is connected to. Normally this hose should be connected to a water level switch, but there is no such part shown for this model.
There is a very good chance for the switch mentioned by Jeff to be the culprit because his advice based on his very good experience. There is nothing to loose for you because you can return any unneeded part purchased from Appliance Parts Pros even if it was installed.
[SIZE=2]:rolleyes:[/SIZE]The switch sounds like a good idea its right under the valves. Its ordered i will let you know.
I replaced the softner switch and now the water works. I guess i need to return the water valves do I need a return # from parts pros. Thanks for everyones help. Do you know we never use the softner switch ever. Who would have thought it would stop all water from comming into the machine.
Thanks Again bgrable:)
You are welcome. We are glad you were able to fix it.
You probably can return the water valve but the test showed a bad thermistor on the original valve. You may want to put the old valve back and see how it works before you return the new one.
In regards of the part return you have to call the APP customer service.
