Maytag Centennial Issue
Hi - I have a Maytag MVWC300XW1 washer that does not agitate or spin when I run a cycle (any cycle - rinse/spin to delicates). During troubleshooting, I found that if I enter the manual troubleshooting mode, the washer will run high/low agitate and high/low spin without trouble. Any ideas what could be wrong?
Since it will work in diagnostic mode this suggests the problem is with the control unit. It is an expensive part and you may be better off with a new basic toploader. If you do decide to fix it you can order from this site and if the part does not fix the problem you can return it.
