Maytag Centennial electric dryer
My Maytag Centennial electric dryer (Mod: MEDC400VW0, Ser: MW4343221)) will no longer heat up when turned on. It still spins but does not produce any heat to dry the clothes. I have tried each setting, and all have failed to heat up.
Does the timer advance on it’s own with dryer running in timed dry cycle? If not, try resetting your AC panel breaker as one leg of the breaker may have tripped. If timer does advance but no heat, then the problem could be the heater coil is open, bad timer, thermal cutoff blown, bad motor heat circuit switch, faulty hi limit thermostat or operating thermostat. Do you have a multimeter to check continuity on these devices?
Eric
