maytag bravos washer
error code f51 help
The “F51” error code means there is a motor rotor position sensor (RPS) failure.
Perform the troubleshooting as described in the attached Tech sheet (page 4, test# 3).
Here are the breakdown diagrams and Replacement parts for Maytag MTW6600TB0 AUTOMATIC WASHER | AppliancePartsPros.com
Tech Sheet - W10092700.pdf (366.6 KB)
