Maytag Bravos Washer Clicking
Have A Maytag Bravocs Mct Washer That After Selecting Cycle It Keeps Making A Clicking Sound Coming From The Bottom Of The Washer. Takes Forever To Start The Cycle And Sometimes Wont At All. My Wife Also Says It Doesnt Drain Well Either. I Have Checked For Clogged Pump, Even Pulled The Tub Unit Out And Cleaned That. None Of It Was That Dirty. The Clicking Noise Is Coming From A Synchronous Motor On The Bottom Of The Washer. I Have Removed It And Inspected It And It Appears Ok?
This fell on the floor while removing the shift actuator on the bottom of the washer. Where exactly does this piece go?
Its a bushing or spacer of some sort.
