Maytag Bravos UL code
Washer keeps getting UL code during last 5 min of cycle even when machine is empty. I already replaced suspension rods but this did not fix the problem. What else can be causing the UL code. I can’t finish spinning out my wash. Can anyone help me? Thank you.
I am having the same problem with my bravos washing machine! we replaced the sensor on the bottom tightened everything we saw and still ul on every load! it doesn’t seem unbalanced, no crazy banging or anything before it stops. Please help!
