Maytag Bravo top load
I have the maytag bravo and it started with just the F code took the stater out and check all the connections and cleaned them. Put it all back to geather and started the machine and now It is showing a f50 code. What should I check next. Sorry don’t have the model of the machine on me at this time
Hi.
In order to assist you , please provide complete model and serial number.
Thank you.
Simon.
Hi.
The F50 code means that motor rotor position sensor (RPS) senses no rotation.
Using the putty knife open the top (one clip on each side) and locate the manual on the side wall.
Go to fault code F50 and follow the test.
Post the results.
Simon.
