Maytag brake assembly replacement
I just received the Brake Assembly, belts, bearings and the Brake Tool that I ordered from Applicance Parts Pros and have 1/2 taken it appart. I removed the pully and am trying to remove the assembly. I see that it screws in and that I need to use the tool to back it off. I loosened up the screw that holds the small clip aginst the threads, however, it really seems locked in there. I even tapped it with a hammer. Am I missing something? Do I need to remove the center shaft first?
Thanks,
You really need a service manual to do this job, and the brake spring is under 200lbs of pressue and can be dangerous so I strongly recommend you do not proceed until you get one.
Unfortunately Maytag will not allow access to its manuals anymore, so I suggest you contact them or search the net. If all else fails it appears you can buy the manual for a small fee from this link.
Download Maytag Laundry Center LSE7806 - The Service Manual Reference & Location Service
