Maytag Atlantis Will Not Run
Hello Parts Pros,
My Atlantis would not run. All power to unit checked out and after reading a few posts here I bypassed the lid switch with a jumper to the red, yellow and black wires. The washer turned on and filled with water. Yay, I thought for sure it was fixed. Problem is that it filled with water and that was it. No nothing after that. No agitation, no motor humming, nothing. Now I have a tub full of water and don’t know what to do? Could it still be the lid switch? I’m perplexed…
[QUOTE=Bsktbll;911714]Hello Parts Pros,
My Atlantis would not run. All power to unit checked out and after reading a few posts here I bypassed the lid switch with a jumper to the red, yellow and black wires. The washer turned on and filled with water. Yay, I thought for sure it was fixed. Problem is that it filled with water and that was it. No nothing after that. No agitation, no motor humming, nothing. Now I have a tub full of water and don’t know what to do? Could it still be the lid switch? I’m perplexed…[/QUOTE]
Well guys, it appears it was the lid switch after all. Seems that the power circuit was tripped after the washer started filling with water. I Reset the circuit breaker and now washer is functioning. Yay…and thanks anyway
