Fills with water like normal but won’t advance and continue. Never had any problems with this unit.
Do you hear the motor running like it’s trying to move? If so pop off the front and check to make sure your belt is on and that you have tension on the belt by adjusting motor accordingly to do so. Here’s some schematics to help you break it down and parts to identify problem.
01-Base parts for Maytag MAV8551AWW - AppliancePartsPros.com
02-Cabinet parts for Maytag MAV8551AWW - AppliancePartsPros.com
Belt access is from underneath machine, not inside front panel. If no noise from motor and timer does not advance and it won’t drain/spin, probably have a bad lid switch. If it does drain/spin, may be faulty water level pressure switch.
Eric
