The AC unit noted above was used only a few times and this year when I went to turn it on, nothing happens, no power in the unit at all. Tried different plugs so I know its getting power but nothing turns on on the unit.
Your model number isn’t pulling up so hard to tell, can you double check the model number off the AC itself?
Possibly a bad switch.
