Maytag A105 will spin but won't agitate
Brand:Maytag
Model Number:A105
Main Symptom:No agitation
What happens & when:Won’t agitate but will spin and expel water
Error Code (if any):No. Too old for that. 38 years old.
Parts or tests already tried:Replaced belts. What’s best to try next? Motor gets pretty hot. Chirping and other odd sounds when spinning.
A105
Nice washer!
A copy:
Maytag Dependable Care washer - wont agitate:
Check for a seized transmission, if you cannot turn the belt by hand the transmission may be seized. There is also a drive lug that may need to be adjusted, the drive lug is under the center (Trans) pulley.
One direction is spin and other direction is for agitation.
jeff sr.
