Hey there,
I have seen many other posters with the same issue, but could not locate any with my actual model. The other day I went to remove clothes from the washer to put in the drier and they were soaking wet. A steady trickle of cold water was refilling the drum. I re-spun it, it drained and I removed the clothes. The trickle continued and it filled the drum. I disconnected the cold water hose from the water source and it stop, but as soon as I hook it back up it starts running in, even with the machine unplugged. Any idea on what part is at fault and whether or not this is something I should attempt to repair on my own?
Thanks in advance!
