Brand: Maytag
Model Number: MAV5000AWW
Main Symptom: does not agitate, but does spin
What happens & when: Agitator stopped working. I could hear a clicking sound when it was trying to move. I was able to drain and spin to empty the tub.
Parts or tests already tried: I took off the agitator and it looks to be in good condition where it attaches to the main shaft. No wear marks on the rib. I cannot seem to take part the 2 pieces of the agitator to see if there is a broken cog assembly inside.
I then tipped over the machine, removed the belt which is in perfect condition as it was replaced a year ago. I moved the center shaft in counter clockwise direction and could see the shaft on the inside of the tub moving. The tub and shaft move in unison, IE: the shaft did not move independently of the tub.
What should I look at next? What would cause the clicking sound? I
