my matag brovos goes in to lb erra looked and wont let it run,:mad: in hand book showing door lach mite be the problem can you help me .tried pulling plug for a minnet no luck .
Anthony,
Hopefully you have a sticky lid lock assembly, or loose connection on the harness.
But here is a copy of the Technical Data sheet, so you can run the board output tests and diagnostic tests, and we can have a better idea of where the problem is.
[ATTACH]2706[/ATTACH]
Good Luck,
Tech Sheet - W10092700.pdf (366.6 KB)
