Manual Door Lock Release?
I have a one month old Maytag Maxima front loader. I was doing laundry last night and I heard a terrible noise and now the door won’t unlock.
My hypothesis is that some change fell out of someone’s pocket, is blocking the drain, so there is still water in the tub and it won’t unlock.
I’ve tried all trouble shooting listed in the manual and on the web.
Is there a way to manually release the door latch? The problem seems easy enough to fix, I just can’t get into the washer to take care of it.
There should be tech notes under the top cover or inside the lower service panel.
If not, or you cannot get to it, here are the instructions for a manual unlock from the tech notes.
[SIZE=3]Manually Unlocking the Door Lock System[/SIZE]
[FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]1. [/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Unplug washer or disconnect power.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]2. [/SIZE][/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Remove the top washer panel.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]3. [/SIZE][/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Reach down along the inside of the front (between tub and CCU) and locate the top of the door switch/lock assembly.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]4. [/SIZE][/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Located on the top of the door switch/lock assembly is a ring-shaped tab.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]5. [/SIZE][/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]Gently pull the tab upward about ¼" or until a click is heard.[/SIZE]
[/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]6. [/SIZE][/FONT][/FONT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][FONT=Swiss 72 1 BT,Swiss 72 1 BT][SIZE=4]The door may be opened.[/SIZE]
[/FONT][/FONT]
