Malfunctioning after the door align
Very strange. The door was misaligned didn’t open well. I loosened the 3 hinge screws at the bottom, align the door and tighten them back. Door works fine.
But after the door fix, the light is on and the turn table rotates all the time when the door is closed. Some buttons on the key pad ( such as clear and clock ) work. But the Start button appears to be dead.
Any help ?
Thank you !
The door switchs are not ajusted correctly. Make sure you ajust them before trying to run the unit again,You WILL damage the unit if you don’t get them rite!!!
Oh, thank you so much. That was it. There were 3 switches that need to be adjusted properly. Poor design.
