Maintaining proper temperatures
Brand:kitchen-aid
Model ktrs20mawh10
Main Symptom unable to keep proper temp on fridge & freezer
What happens & when: after replacing the evaporator fan I can’t keep the refrigerator temp in the proper range which also affects the freezer. If the fan blades are on wrong or the wires are on the wrong terminal make make motor run backwards or force air wrong direction?
Ensure you have the correct evaporator fan and blade. The wires should not be the issue, but you could have the blade incorrectly, or have ice blocking the airflow.
https://www.appliancepartspros.com/whirlpool-evaporator-fan-motor-482731-ap3110929.html
