Main top cooktop and burner replacement
What is the procedure for replacing the main top and right front burner on my Frigidaire GLEC36S8EBB cooktop? How do I remove the cracked top? How is it secured?
Here is your parts breakdown.
Replacement parts for FRIGIDAIRE GLEC36S8EBB Frigidaire/cooktop | AppliancePartsPros.com
The manual for this unit does not come up.
But looking at the prices for the parts you would probably be better off replacing it.
I have the replacement parts in hand. I just need to get the old top off and put on the new top and one new burner. Looks like I have to remove the entire unit from the cabinet and see how the top is attached (screws, welded???). I can not tell from the bottom.
