Brand:GE washer
Model Number:gtw680bpl1dg
Main Symptom:main control board
What happens & when:following program instructions and when I push start button screen goes black and can’t do anything
Parts or tests already tried: brand new control board
With the unit not allowing you to program the board, it sounds like a there could be a communication issue. Double check all connections to make sure that there are no loose or damaged wires. If this is not the case then you may have received a faulty board.
Are you sending me a new board. Everything checks good. I need asap cause have laundry to do
Can some please contact me via this platform
Brian
