First, thanks for your help. This has been a perplexing issue that has me boggled. Washer gives an error code Hr when there is a load running. Does not when it runs a cycle with no load. Shock absorbers on the left side seem rusted which could be causing it to make the tube move more than usual when a load is present. Jostled any visible wiring harnesses while the washer ran a cycle with no load to see if I could recreate the error but got nothing.
So what could be going on here? Thanks for your help
