Magic chef wall oven from 1990
wall oven light work, power to oven works, but no red light to thermostat or the coils don’t heat up. no heat are there parts for this oven?
Cannot find a listing for the given model number but here are part for a 98FA-4CX. It is probably very close to yours.
Does look like most parts are obsolete.
Replacement parts for MAGIC CHEF 98FA-4CX WALLOVEN- STD ELE | AppliancePartsPros.com
How do you know that “power to oven works”?
Have you measured it with a meter?
The oven light runs off of 120 volts but the elements need the full 240 volts.
Perhaps the oven on light also need2 240 but I cannot confirm this as I cannot find a wiring diagram.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug. You may be hard wired.
L1 to L2 should be 240 volts
If OK
If OK
[COLOR=“Red”]Be careful as 240 volts is lethal !!! [/COLOR]
the wall oven is direct to fuse box. My son touched some wires on the back of analog turn and got zapped. :confused:
You have to actually measure it.
By the sound of it you may want to get a pro in unless you have a couple extra sons.
[SIZE=“3”][COLOR=“Red”]240 volts is lethal!!![/COLOR][/SIZE]
