Magic chef stove not igniting
The gas stove on my magic chef oven is not igniting. the ignitor seems to be glowing and when I bang the stove with my hand it seems to ignite the flame. Is the ignitor defective> thanks for the advice.
Mike Robinson
Measure the current drawn by the igniter. If it’s 3.2 amps or less, replace the oven igniter.
Here are the breakdown diagrams and Replacement parts for MAGIC CHEF 31FA-8KX-OC Range - F/s Std Gas | AppliancePartsPros.com
thanks Gene,
Using a volt meter can i measure the draw by removing the ceramic wire nuts and contacting one wire with each probe?
Thanks Mike R
Yes, you can if it has an amperage scale. The meter probes should have a good, reliable connection for at least a minute.
