I have a magic chef model 31ba-15w range that I can not find a manual for.
2 days ago it was working fine. Now the pilot is on, the flame gets brighter when thermostat turned on, but no ignition. From reading the forums, I assume it is the ignitor.
Hoping for assistance in confirming my diagnosis and the proper replacement parts.
I posted this earlier..
[quote=pitstop;131654]I have a magic chef model 31ba-15w range that I can not find a manual for.
Thanks[/quote]
If there is a standing pilot then there is a different kind of the ignition in your oven. The problem can be a clogged pilot or a bad gas safety valve.
In order to provide more accurate advice we need the complete model number of the oven. The model number you posted does not come up. Verify and repost it.
Gene,
I could not find that model number at Magic Chef website. It is correct and the only one I found.
Here is the plate info:
Model 31BA-15W
serial number 31X148 136113
by Magic Chef Cleveland TN
for complete instructions see manual 102GC 33M
Did you figure out what kind of ignition is in your oven?
The model number does not come up probably to the age of the unit. Try to talk to the APP team - might be they can find more information.
