Magic Chef Infinite switch Question
Brand: Magic Chef
Model Number: 7858xuw
Main Symptom: Oven Surface Element, when turned off, will stay warm to the touch 2+ hrs
What happens & when: Oven Surface Element, when turned off, will stay warm to the touch for 2+ hrs
Error Code (if any): No codes
Parts or tests already tried: I swapped the Infinite switch from the one I never use, the rear left, to the broken one; same problem. Also, I swapped the Element from a different location; it’s still the same. The Question I have is if one Infinite switch is broken, and i switch them, will I have the same problem?
If there is one infinite switch that is faulty then it would need to be replaced. It should not affect the rest of them.
