Magic Chef gas oven won't light
Hi, I have a Majic Chef gas oven that just decided to stop working and I’m hoping you might be able to remotely diagnos it. I can set the temperature control but the oven never reaches the set temperature. The ignitor glows a bright orange but the gas valve doesn’t see to turn on and the burner doesn’t ignite. That having been said, it must fire at some time beause the oven temp will climb to about 200F if I wait long enough. Also, when this happens, there is a slight gas smell. I’m guessing that the ignitor is bad/weak rather than the gas valve as the broiler still works. Can you provide any suggestions?
Doug
Sounds like a classic case of a bad igniter. The glow should be white not orange. Replace the bake igniter and all should be back to normal.
Click here for the Magic Chef (Maytag) oven igniter.
Breakdown diagrams for your Model 34HA-5TKXW
I have the same problem. The ignighter glows a bright orange. I tried to use a lighter adn got a VERY weak small blue flame that flickered out after a second or two, so I think it may be the regulator for the oven.
The range top burners all work but they are actual mechanical knobs that regulate the gas. I think that an electrical signal is sent to the ovens gas regulator and tells that to come on.
Could it be this? Also if the gqas pressure is weak for some reason would it not allow gas to pass
Keith,
Post your oven model number please.
the number on the sticker on the door is
8114p471-60
I checked it out again last night and there is definitely no gas coming out when the igniter is on. Would the “bake valve” not open if the igniter was not hot enough? It glows bright orange and is pretty hot but I read on here that it should be almost white.
I am assuming it has to be either the bake valve or igniter. Any info on this issue would be greatly appreciated.
Also I took the black cover off from under the thermostat and stove top burner controls. There seems to be some sort of regulator knob on part that sends the gas down to the stove. You can turn it about a quarter turn. Tried both ways thinking it may allow more gas to flow to bake valve but no go
Not a good idea. Try to turn it back the way it was or this basic igniter problem will turn into something else.
Your igniter is not drawing the correct amperage number, which is why there is no gas flowing through the valve - the valve needs correct amperage from the igniter in order to open.
8114P471-60 is a part number for the little sticker you found. But that’s alright. This number tells me that yours is a Maytag made stove, which means it should have a flat bar igniter, which means you can use the same oven igniter I mentioned earlier.
OK thanks for the info. I will keep you posted. Thanks again
also I found the part on ***** here:
link removed by admin
Keith,
You’re welcome to post your repair questions any time. That’s why we’re here. This is a free service we are offering and we certainly would never make you purchase parts from us. But please, out of common courtesy, don’t post links to our competitors.
I hope you understand.
OOOOPS. Sorry about that didnt realize that you were affiliated with the site that sold the part and that this forum is supported by that. My bad.
Magic Chef 21EA-2KX. No igniter glow. I measured continuity and the igniter has continuity, but the bake valve does not (even on a high-ohms setting). The rest of the circuit seems to have continuity at least back to the terminal on the spark module. There’s supposedly a fuse (which I can’t find) in series with the igniter and bake valve, but I’m thinking it’s got to be an open circuit in the bake valve. Does this sound right?
Bake valve is an NC-4125-5.
I think i have the same problem, im not sure, though, any insight would be grateful, It wont light, i looked at it, i tried lighting the pilot, i took out the bottom cover, to get to it, but it wont light, and when i have the gas on, no gas, is coming out or my house would smell like it right now. the # on the door for the oven is 8114P351 60
Oh and the ignitor doesnt light up at all
[quote=koohgar;223]Hi, I have a Majic Chef gas oven that just decided to stop working and I’m hoping you might be able to remotely diagnos it. I can set the temperature control but the oven never reaches the set temperature. The ignitor glows a bright orange but the gas valve doesn’t see to turn on and the burner doesn’t ignite. That having been said, it must fire at some time beause the oven temp will climb to about 200F if I wait long enough. Also, when this happens, there is a slight gas smell. I’m guessing that the ignitor is bad/weak rather than the gas valve as the broiler still works. Can you provide any suggestions?
Doug[/quote]
HOW DID YOU FIX???:(My oven seems to light and broil looks good but oven portion when set you smell gas and keeps at a low varying tempature after replacement of thermastat temp contol knob.What is making this happen still?Sounds like I have same problem here.
I have a maytag oven model; MGR4451ADQ that will not light. I took off the door, took out the racks, and removed the floor board and heat shield. I turned the stove on and nothing lights up down below and no sound of gas either. Up top when I hit bake and pick a temp it looks like it’s going to work, then makes a clicking sound (I’m assuming that is the thermometer engaging) and just reads 100 (for the temp) without making any other noises, no smell of gas, and nothing ignites or gets hot down below.
Please let me know your thoughts. . . .
Thanks, Andy
  1. The main problem I am having is the oven igniter glows bright orange. but won’t light.
  2. Also been having issues with range top burners… intermittently the ignitor wouldnt produce the sparks to light a burner. (no clicking noise)
Hello I have a magic chef oven model CGR374OADW, I need to replace the ignitor. The top burners work but the inside stopped working after I did a self clean. Can you send me the model number for the ignitor and the over schematic? Thank you
Hi, sounds like i’m having the same igniter issue but can’t find a model number. Any suggestions on how to get the right replacement?
My oven won’t go on, I thought it was the igniter, changed it but nothing happened, what else could be, any suggestions?
